I need to save some Indesign document to older versions (idml).
But i can't find any samples from javascript in combination with Switch on how to do this.
Can somebody point me to some sample files.
The manual from Switch isnt very helpfull.
JavaScript to Save as idml file in Indesign
I am using the Indesign Configurator to process my jobs.
The settings i use are:
Open = Automatic
Command = None
Save = Use Script
var regex = /.indd/gi
var fileName = app.activeDocument.fullName.replace(regex, ".idml");
app.activeDocument.save(File(fileName), true);
Do i have to use the $code instead of app.activeDocument to get it working?
Or do i use the code in SwitchScripter?
I am getting errors that no documents are open.
Open = Automatic
Command = None
Save = Use Script
Yes, you do and you have to fill out the $outfiles array so Switch knows what output files your script created. See the Switch help: Introduction - Advanced topics for designing flows -Javascript for applications.
Here is the code:
var tempDir = "/Users/fp/Desktop/";
var fileName = $doc.name.replace(".indd",".idml");
$doc.exportFile("InDesign Markup (IDML)",tempDir+fileName);
$outfiles = []
$outfiles.push(tempDir+fileName);
$doc.close;
Switch will automatically remove the temporary file, by the way.
Here is the code:
$outfiles = []
$doc.close;
