Dears
here is my xml sample
8
4
i am trying to use the below scripts expression to get data
var jobDataset = job.getDataset( "Xml" );
var ups =jobDataset.getPath("/data/upsnumber");
var copies=jobDataset.getPath("/data/copynumber");
but always show me error message
No matching slot found, available overloads are: QString DatasetXML::getPath()
Real appreciate anyone can help me to solve this problem.
Nick
why i can't get the value from XML
Hi Nick,
here is a script expression that will give you the value from your XML sample:
var theCopynumber = job.getVariableAsString('[Metadata.Text:Path="/data/copynumber",Dataset="Xml",Model=XML]')
In this example you'll get the valua as string, you can also use getVariableAsNumber, getVariableAsBoolean or getVariableAsDate, depending on your needs.
Hope this helps?
Carine
Hope this helps?
Carine
Thanks much! it works.
but i found i get a wrong value perhaps. i am trying to check it with 'alert' function. but it seems it is not supported. how can i check the procedure variables like debug.print?
Thanks again
Nick
carineb wrote: Hi Nick,
Hope this helps?
Carine
Thanks again
Nick
Hope this helps?
Carine
You can ceck the variable value:
job.log(1, 'value=' + myvariable)
Real appreciate! works!
Thanks much
Nick
caio wrote: You can ceck the variable value:
Thanks much
Nick
