search function broken
tz8
try it, search all you like, you will always find zero posts
please fix it!
Cheers,
Thorsten
PS: there is no board to tell you about Forum issues! ;)
anma
Hi Thorsten,
I just checked and can confirm that I get results on my Search request. What I did:
- Select Search
- You will see two fields where you can enter your key words "Posted by" and below that "Posts". Make sure you enter your key words in the field labelled "Posts" e.g. the word script. As a result I get 20 pages.
Please try again and confirm if all is OK or you still have problems.
Best regards,
Angelo
tz8
i used the searched function a hundred times and for the last couple of days i always used the wrong field?
If this was the error: sorry for reporting a non existent bug ;)
