Text tag using pitstop server and Enfocus Switch
I am creating a a flow where I :
Take an imposed Pdf of the sheet size (example 19 x 25)
Add a plate with setbacks
Add a density bar
Add text tag for identifying color separations on plate
I am having trouble with the last step. I can not for the life of me figure out how to make a text tag with the correct color separations. For example
I have a document that prints as CMYK+Pantone 186 C
I can create a text line that Reads;
Cyan (on the Cyan Separation)
Magenta (on the Magenta Separation)
Yellow (on the Yellow Separation)
Black (on the Black Separation)
Pantone 186 C (I can not put this on the 186 seperation without manual intervention)
Any ideas or suggestions are greatly appreciated
Thanks,
Paul Hough
Plate Text tag using pitstop server and Enfocus Switch
D Kelly,
Thank you for the quick response. unfortunately this does not work. You can indeed pull the color names in from stats.colorants, but you can not use the same variable as a fill color. The fill color variable has to be a boolean. ( if Boolean == True then fill Color = Static value)
Unless I am missing something.
Thanks,
Paul Hough
Thanks,
Paul Hough
ah, I missed that part of your requirements. I would recommend using Apago's PDFspy to retrieve the color names and spot simulation values. A simple script could read the values from PDFspy and set the appropriate variables for color names and values.
