How do I format the font styles in javascript to InDesign Doc from Switch?
neecerp
Using Javascript to open InDesign, read XML and create a pdf out of Switch.
How do I format portions of the text that is written. Here is what I have so far....but it seems to only pick up the paragraph styles that are in Indesign???
//This is a command javascript so Switch takes care of opening the file
//$error and $doc come from Switch opening the file
//Start all scripts with this basic error routine
if(($error == null) && ($doc != null))
try
//Declare variables available to javascript $doc is the file opened by switch and replaces app.activeDocument
var H = $doc.documentPreferences.pageHeight;
var W = $doc.documentPreferences.pageWidth;
$doc.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
//Pickup data from switch from the 5 arguments
var arg1 = $arg1;
var arg2 = $arg2;
var arg3 = $arg3;
var arg4 = $arg4;
var arg5 = $arg5;
with ($doc.pages.item(0)){
with (textFrames.add()){
geometricBounds = [16, 3, H -6, W -.5];
insertionPoints.item(0).contents = "Magento Order ID - " +arg1+ arg2;
paragraphs.item(0).justification = Justification.leftAlign;
var arg1 = $arg1;
var arg2 = $arg2;
var arg3 = $arg3;
var arg4 = $arg4;
var arg5 = $arg5;
geometricBounds = [45, 3, H -6, W -.5];
insertionPoints.item(0).contents = arg3+ "r" +arg4+ " This is a test-"+ arg5;
function createStyles(){
var stlHead = g.doc.paragraphStyles.add();
stlHead.name = "MageDocID";
try{stlHead.appliedFont = "Arial Black";}catch(e){}
stlHead.pointSize = "14 pt";
stlHead.startParagraph = StartParagraph.nextPage;
var stlAuthor = g.doc.paragraphStyles.add();
stlAuthor.name = "PSorderID";
try{stlAuthor.appliedFont = "Arial"}catch(e){}
stlAuthor.pointSize = "14 pt";
stlAuthor.spaceAfter = "9 pt";
var stlpara = g.doc.paragraphStyles.add();
stlPara.name = "PSPickID";
try{stlPara.appliedFont = "Code39 Regular"}catch(e){};
stlPara.pointSize = "36 pt";
stlPara.spaceAfter = "36 pt";
function mapTags(){
g.doc.loadXMLTags(File("/Users/switchmac/Desktop/Indesign Add Text from XML 2/MagentoFatXML.xml"));
g.doc.xmlTags.item("Root").name = "MageDocID";
g.doc.xmlImportMaps.add("MageDocID", "MageDocID");
g.doc.xmlImportMaps.add("PSPickID", "PSPickID");
g.doc.xmlImportMaps.add("MageOrderID", "MageOrderID");
g.doc.mapXMLTagsToStyles ();
//This is a command javascript so Switch will take care of saving the file and closing
catch(theError)
$doc.close(SaveOptions.no);
$error = theError.description;
TOP CONTRIBUTOR
Check out Indesign scripting forum @ http://forums.adobe.com/community/indes ... _scripting
