I would like to run the following in line command using the Execute command tool:
/Applications/FlipPDFProfessional.app/Contents/MacOS/./FPCMD -f /Volumes/RAID Strip 1/flip/in/pag_1-10.pdf -o /Volumes/RAID Strip 1/flip/out/ -n test
(this is the command used in a shell)
where FPCMD is the application, -f /Volumes/RAID Strip 1/flip/in/pag_1-10.pdf is the input file absolute path, -o /Volumes/RAID Strip 1/flip/out/ the output folder absolute path and -n test is the output file name.
The output of the application is not a single file but some files, as the result is a flip-page.
How can I do it?
In the "Execute command" tool you put
/Applications/FlipPDFProfessional.app/Contents/MacOS/./FPCMD as the "Command or path".
In the "Arguments" you "Define single-line text with variable" and in there you build the string:
-f "%1" -o "%3" -n [Job.NameProper]
%1 will be substituted by Switch by the path to the input file. %3 is a folder that Switch will create and where the output file(s) can be written. -n [Job.NameProper] because I am assuming you do not want the output file to have the name "test", but the name of the incoming job.
Then you also have to give Switch a hint that the output files will be in a folder by setting "Output" to "Result in folder".
I have not tested it with this application, but this seems the logical way to set it up. Looking forward to your feedback.
Hi Freddy,
what you have suggested works fine.
The only problem is about the variable %3.
It get the following information:
/Users/serverx1/Library/Application Support/Enfocus/Switch Server/temp/3/ScriptElement/1/92/ExecuteComandTemp/
that is a temporary folder but in the path there is a space and I think that it is a problem.
I solved with this workaround.
Instead of the variable %3 I set the real final path
/Users/serverx1/Documents/out/[Job.Name].
In this way I get what wanted.
I am glad you have a solution, but the spaces are not a problem when you take into consideration the following two points:
- write "%3" and not just %3 so the parameter is passed quoted
- when "%3" is passed to a shell script as for example the second argument you should quote the argument inside the script as well: "$2" instead of just $2.
