Hi
I need to get a preflight-check that sees if there are any graphics outside the trim box and inside the bleed box. But only if there is real object, not empty frames or other non graphical objects.
I find this action;
select objects inside/outside region (outside trim box)
select objects inside/outside region (inside bleed box)
AND
log selection
But that finds everything even if just the bleedbox is active..
Has any one else some suggestions?
How to see if there is graphics in bleed area
There is a standard preflight check in PitStop to check bleed. It is in the Page section. Just activate it and fill in the values.
The inverse check is also available: Safe type zone. This checks there are no objects that are too close to the page edge (useful in book printing).
