I was wondering if anybody has used a javascript in Switch to detect if an incoming image has a workpath/path without opening the file in photoshop first?
Having done a search on the internet I did find that somebody had used Javascript via Bridge to detect and rename a Path in an image file.
The reason behind the question is we send out a lot of images to be cutout, on receiving the files back sometimes they haven't named the path to Path 1 and left it as Workpath, sometimes the file coming back may be a jpeg or photoshop file with a Path.
What we would probably look to do is 1) check to see if a path is present 2) if so is the path named correctly if not rename to Path 1.
Any thoughts/suggestions
Detecting if a Path is present in an incoming image file
McCannManchester
I do not have a turnkey solution for this, but what you could try is to use Imagemagick's identify command with the -verbose option. On an image on which I tried this it resulted in this output:
exif:XResolution: 3000000/10000
exif:YResolution: 3000000/10000
jpeg:colorspace: 2
jpeg:sampling-factor: 1x1,1x1,1x1
rdf:Alt:
signature: 1baefabc677612f5b01d7777d705497537c1e28d8a0ea558c320cfe76aee5735
xmpMM:DerivedFrom:
Clipping path:
<path style="fill:#00000000;stroke:#00000000;stroke-width:0;stroke-antialiasing:false" d="
M 163.268,1271.18
C 163.815,1265.38 164.409,1263.1 168.459,1257.74
C 172.509,1252.37 177.009,1248.48 179.062,1244.53
C 179.719,1239.72 179.959,1236.73 179.959,1234.33
C 179.215,1233.54 178.724,1233.24 178.735,1231.88
This at least shows that there is a clipping path in the file, but it does not show the name, at least not on the one file I tried it with. It may be worthwhile investigating your files with the Imagemagick tool to see if you can infer any information from it. If you can, it will be a lot easier to run Imagemagick from the command line and parse the output than it will be to parse the image file.
To run Imagemagick on the command line I used:
/opt/ImageMagick/bin/identify -verbose image_with_mask.jpg
Keep us posted.
jpeg:colorspace: 2
rdf:Alt:
xmpMM:DerivedFrom:
Clipping path:
M 163.268,1271.18
Keep us posted.
Use this script in the command section of photoshop configurator.
try
var newPathName = "Path "
var numberOfPaths = activeDocument.pathItems;
if (numberOfPaths.length > 0)
for (n =numberOfPaths.length-1; n>-1; n--) {
var a = numberOfPaths[n].kind;
if (a == "PathKind.NORMALPATH" && newPathName + n != numberOfPaths[n].name ){
numberOfPaths[n].name = newPathName + n;
if (a == "PathKind.WORKPATH" && newPathName + n != numberOfPaths[n].name ) {
catch(e)
$error = e
//PathKind.CLIPPINGPATH
//PathKind.NORMALPATH
//PathKind.TEXTMASK
//PathKind.VECTORMASK
//PathKind.WORKPATH
try
catch(e)
$error = e
//PathKind.TEXTMASK
//PathKind.WORKPATH
