XML pickup tool
sherczog
Can someone help me with the tool xml-pickup?
I want to catch a file as defined in an xml.
The flow gives an error: Failed to find asset ''
An xml file (called: testXml.xml) containing:
pad
E:test.txt
And in Powerswtich an Single-line text with variables defined: [Metadata.Text:Path="//field[tag=pad]/value",Dataset="Xml",Model="XML"].
Where do I go wrong?
mattbeals
As far as I know this requires a script expression rather than a condition with variable. But I do not have a script that would do this.
mattbeals
Here, try this:
http://www.mattbeals.com/misc/inject_job.zip
http://www.mattbeals.com/misc/inject_job2.zip
What I did was use the XML as the asset itself. Then I use the inject job to point to a fixed location where the job resides. All the metadata that comes inside the XML is preserved and can be used for routing/processing.
The second sample has a UNC path to the asset itself.
sherczog
It works!
Although I do not understand how. How does PowerSwitch know where the tag is for the path? In the manual it says : “the asset (the xml file) must contain data of the appropriate type..” What is the appropriate type?
The method in my original question (XMLpickup – Metadata refers to asset) suggests that the structure of the xml is flexible as long as your Xpath statement is correct... but that didn’t work, so I guess my logic is not sound.
Maybe Enfocus can provide with some more information...but for now I can use your solution.
thanx
bens
sherczog wrote: And in Powerswtich an Single-line text with variables defined: [Metadata.Text:Path="//field[tag=pad]/value",Dataset="Xml",Model="XML"].
The xpath expression is not completely correct. Try this one:
[Metadata.Text:Path="//field[tag='pad']/value",Dataset="Xml",Model="XML"]
