Is there any way to delete unwanted layers in a pdf? I need the pdf continued to be layered so I can't flatten it.
And it will not help to make them invisible, I need to get them all gone.
I'll tried to find any way inside Pitstop but can't find any. I knew that pdfToolbox can do it, but I don't want to buy more software.
My workflow so far is this. Make an layout in Indesign. I need to have some special layers for our cutting machine. Then I use MadeToPrint and MadeForLayers to print out two pdf's with respective layers how is needed for one print-file and one cut-file. But in the cut-file I don't want the "graphics" for example and in the print-file I don't want the cut/grease and so on..
I have visible/invisible layers to make the right content to the right pdf. But Indesign puts all layers in both pdf, just visible/invisible.. And therefor I need to delete some layers..
So any suggestions I'm happy to hear. We have Pitstop Server and Switch 11 with most modules.
Thomas
