Hi Guys ...
Im trying to build a test machine in OS X 10.9 as my new MacPro will come with that OS ... Ive found hurdle number 1, and was kind of expecting it. Were still using Switch 11 U 5 as we think its nice and stable. As I mentioned in another post I had a few issues when I tested 12 some weeks ago so backed out to 11 ... Version 11 wont even start on Mavericks, from my investigation it looks like something to do with the FLEXNet licensing software. So I would have thought it possible to fix but understandably 12 is the future !
Anyone try this and have a solution or as my reseller has told me ... "Switch-12 is the lucky number for Mavericks" ...
Thanks in advance !
Mitch
Any way to run Switch 11 on OSX 10.9 ?
Your analysis is correct: running on Switch 11 on Mavericks will not work because of Flexnet. Believe me, we have tried, and then it took several weeks before we had a solution. Do not waste your time on this.
Thanks freddyp ... Someone suggested looking at running a VM so Im looking into that ... depends on how long until the 12 U 1 update comes out ...
Thanks again ...
Thanks again ...
