How can I debug a value of a variable in JavaScript?
thanks
s.log(1, "variable = " + variable);
In Switch 12 there have been changes to reduce the number of messages considerably. As a result of that there is a slight change in behavior for s.log.
Level 1 will still display a message in Switch Scripter, but not in the Messages pane anymore (the same is true for -1 (debug)). So for regular debugging in Switch Scripter you can use that, but should you want to see the message in a running flow you will have to use 2 (or 3).
Note that this is also the case for "Log job info".
var re ="5454564";
var s=Switch;
s.log(1,"variable = " + re);
TypeError. Undefined member function 'log' for object '[object FactoryObject]' of type: 'FactoryObject'
var s=Switch;
The variable "s" is already defined.
var re ="5454564";
s.log(2,"variable = " + re);
var re ="5454564";
Well, it can work.
