I am trying to make a quick "save as" flow to save down Creative Cloud Illustrator files to CS6.
I am pretty close, if I replace the path to the Desktop for the destination file, it will resave my file to the desktop. I thought if I replaced it with the $outfolder, it would place it in the output folder with the same file name. Instead the script just errors out.
iDoc=app.activeDocument;
var destfile = new File($outfolder);
var aisaveOptions = new IllustratorSaveOptions();
aisaveOptions.compatibility = Compatibility.ILLUSTRATOR16;
iDoc.saveAs (destfile, aisaveOptions);
Save as CS6 from CC
Ok this has got me a little closer, it will create the temp file on the desktop, but it will not move it to the final folder of the flow.
Failed to place job '_0CIP5_Untitled-1.ai' in folder 'Output'
$Doc=app.activeDocument;
var tempfile = new File("/Users/wfadmin/Desktop/" + $filename + ".ai");
$Doc.saveAs (tempfile, aisaveOptions);
$outfiles = []
$outfiles.push(tempfile);
$doc.close;
$outfiles = []
$doc.close;
Do not set $doc to app.activeDocument, and certainly not $Doc.
It will work when you write the output to your Desktop, but it is cleaner to use $outfolder. Check the part on "Javascript for applications" in the Help to find an overview of all the variables you should use.
