freddyp wrote: Then just write
currentbook;
as the last line of your script expression. I thought that was clear from the explanation.
job.log(2,currnetbook)
The line above can see the variables return a value, but this value is undifined
PageWidth how to assign a value to a variable?
If
job.log(2,currentbook);
gives you a correct value in the messages. And
currentbook;
as the last line of your script generates and undefined error message, you are doing something wrong. You may want to check there are no lines with spaces after the last line.
currentbook;
freddyp wrote: If
currentbook;
Problem is: currentbook returns the value of this variable is not correct.
currentbook;
