	I'm setting up a flow where I need to check if a job folder going through a flow contains a folder(or folders). If it does contain a folder, I'd like it to go to an outgoing connection and if it doesn't I'd like it to go to a different outgoing connection.
	Is this possible with Switch scripting?
	Thanks for your help,
	Danny
						Looking to sort jobs containing folders...
In script you'd use job.isFile() or job.isFolder()
You can also use Switch variables [Job.IsFile] and [Job.IsFolder]
first:
create a script where connection type is "Filter" (include/exclude folder set to No).
then you can use this script:
var jobDir = new Dir( job.getPath() );
var jobFolderList = jobDir.entryList( "*", Dir.Dirs|Dir.NoDotAndDotDot );
if( jobFolderList.length > 0 )
job.log( 1, "Job " + job.getName() + " contains " + jobFolderList.length + " folder(s)" );
// the job folder contains folders
// do stuff with it
job.setPrivateData( "folders", "true" )
job.sendToFilter( job.getPath(), job.getName() + "_withFolders" );
else
job.log( 1, "Job " + job.getName() + " contains no folders" );
// job folder does not contain folders
// do stuff with it
job.setPrivateData( "folders", "false" );
job.sendToFilter( job.getPath(), job.getName() + "_noFolders" );
on the outgoing connections apply a file pattern in "include these files" with "*_withFolders" or "*_noFolders"
that should do it
// do stuff with it
else
// do stuff with it
that should do it
Nice!
It works great tz8, thanks for your help.
