Using VBA Word Macro
bepsy72
Does Anybody know how to use word macro inside Switch?
I need to make some text processing before generating a pdf from word files.
I try to use Define script expression in the macro menu and put inside some vb code but it doesn't work...
thank you
The "Macro" property of the Word configurator requires you to specify the name of the macro, not the VBA code!
You can use a script expression on that property, but that is to use a piece of Javascript code to determine the name of the macro to be used.
