Adobe InDesign CC 2014
CSheflo
Can you run the InDesign CC 2014 in the switch server. Wants to default to Adobe InDesign CC. Not sure how to force it to use the current version or if there is a new configurator?
Thank you
TOP CONTRIBUTOR
Indesign CC 2014 is not supported by Switch 12 update 2.
CSheflo wrote: Not sure how to force it to use the current version or if there is a new configurator?
Right click on the element in the "Flow Elements" pane, then "Set path to application". It's not supported but we throw caution to the wind and use CC 2014.
