.insertPages by Acrobat
nicktazo
Dears
i am trying to use below script to insert newPage in opened PDF but failure
$doc.insertPages({nPage:$doc.numPages-1, cPath:"blank.pdf"});
the Error will be prompted by app as
"RaiseError:file problem"
Could you kindly help me to get one solution or a sample of inserting.
Thanks much
Nick
pcobee
Here are two scripts for inserting blank pages into a PDF. It does not require the use of a "blank" PDF. The first inserts a single page at the indicated insertion point. The second inserts a page before or after EVERY page in the PDF based on the value of Argument 1.
// This script can be used to add a single blank page to a PDF:
* $arg1 = Page Insertion point
0 will put before page 1
> 0 will inserts after page number passed in Arg1
Author: Paul O'Brien, AccuLink
if($error == null)
try
var Rect = $doc.getPageBox("Crop");
$doc.newPage($arg1, Rect[2], Rect[1]);
catch(theError)
$error = theError;
$doc.closeDoc( {bNoSave : true} );
// This script can be used to add a blank page before/after EVERY page
0 will start first blank page at front of PDF
1 will start first blank page after first page
if($error == null)
try
if ( $arg1 == 0 ) {
for ( var pagePos=0; pagePos<$doc.numPages; pagePos+=2 ) {
$doc.newPage(pagePos, Rect[2], Rect[1]);
else {
for ( var pagePos=1; pagePos<=$doc.numPages; pagePos+=2 ) {
catch(theError)
$error = theError;
pcobee wrote: Here are two scripts for inserting blank pages into a PDF.
Thanks for sharing, man!
