I'm trying to rename a file such that each file is incremented by one dependent on the first 8 characters.
ie if I put in 20140101_matt, out comes:
20140101_matt01
20140101_matt02
etc
if I put in 20140102_matt, out comes:
20140102_matt01
20140102_matt02
I'm struggling to get Switch to recognise the [1,8] segment of the filename proper to achieve this.
Any help greatly appreciated!
Matt
Increment file name by 1 based on first 8 characters
I think you should see if there's a better way to do this, but what I would do is keep the increment value in private data somewhere. Then, whenever it encounters your rename, do a replace and use filename proper segment 1-14 (or whatever) and concatenate the version number from private data. Then do another private data write and increment the version number using math in single line text with variables. The leading 0 introduces a problem though.
MattV wrote: Thanks for the response.
Is there no way to specify the first 8 characters (segment [1-8]) for example to use as the ID?
Are you asking how to grab the segment itself or are you looking for something else?
I'm attempting to add 2 numbers to end of the filename proper using the 'Switch > Counter' parameters in the renaming element.
For example, the following two files would be renamed as such:
20140101_eop -> 20140101_eop01
20140101_eop -> 20140101_eop02
But, a different dated file would reset the counter to 1 again, so that it would be:
20140102_eop -> 20140102_eop01
and not 20140102_eop -> 20140102_eop03
So the segment [1-8] would need to be the ID, so that switch recognises the change.
I hope that makes sense!
Matt
Matt
