Logging flow progress
ArielRauch
I would like to know if there is any shortcut (not writing a script and put it almost everywhere) for creating logging messages for every jobstate that has a value?
That means, that every time a job passes a "station" where a jobstate is defined it is automatically logged.
Ariel
ArielRauch
Only to make the question a bit clearer:
I want to document the way a job makes during the flows for later statistical analysis. Of course I would like to see those "stations" also in the switch log.
Anyone?
There is a "Log job info" element that will do just that.
ArielRauch
If I understand this option correctly (and I am not sure about this) I can only use one variable per message.
Am I right?
compendio
Ariel,
I don't know the exact functionality but maybe something more than the default:
Impressed Switch Logger
Best regards,
Thomas
ArielRauch wrote: If I understand this option correctly (and I am not sure about this) I can only use one variable per message.
Am I right?
You can only log one message at the time, but you can use several variables in that message and you put a special separator in between, so you can easily decompose the message afterwards.
ArielRauch
got it, Freddy - thanks
