Create InDesign Package
Terkelsen
I'm looking for a way to have the InDesign configurator create an InDesign package. I guess I'll need a script to be run by the configurator. Any help?
This will do the trick. Save it to a jsx file and use that file in the "Save" - "Use script" property of the Indesign configurator.
$outfile = $outfolder+"/"+$filename;
var to = new File($outfile);
var copyingFonts = true;
var copyingLinkedGraphics = true;
var copyingProfiles = true;
var updatingGraphics = true;
var includingHiddenLayers = true;
var ignorePreflightErrors = true;
var creatingReport = true;
var versionComments = "comment";
var forceSave = true;
if(($error == null) && ($doc != null))
try {
$doc.packageForPrint (
to,
copyingFonts,
copyingLinkedGraphics,
copyingProfiles,
updatingGraphics,
includingHiddenLayers,
ignorePreflightErrors,
creatingReport,
$outfiles.push($outfile);
catch(theError) {
$doc.close(SaveOptions.no);
$error = theError.description;
Terkelsen
I can confirm that this works just fine, Freddy. It even works with InDesign CC 2014 though this is not yet officially supported by Switch ;-)
However CC 2014 adds the possibility of saving both idml and PDF together with everything else in a package. Can anybody help to add these features to the script? This would even mean that you could turn off everything else and just save the idml, which I think is a much requested feature.
Obvious things to implement in a coming version of the InDesign configurator i.m.h.o.
Thanks for sharing this solution, Freddy. I will definitely try this out.
peterlk
Hi Freddy,
I'm looking for a InDesign CC2015 Server script, that will save an InDesign Package - can you twist the script you already made for InDesign?
Freddy - I got it - it works in InDesign Server 2015 too ;)
