We're having a pretty hard-to-pin-down issue for the past couple of months. Our production machine runs on a mac and it is using tons and tons of memory. The server has 20GB of memory (could be more but honestly not bad) and after Switch is running for a few hours, the "Free" ram will go down to maybe 1GB. When it gets bad, the "Free" will only be a few megabytes. When this happens, the "Inactive" memory skyrockets to 12-16GB.
Here is a screenshot of what it looks like when Switch is running well:
I'll take another screenshot when Switch gets bogged down. Essentially, it looks like the above but the blue part of the pie (inactive memory) encompasses everything in the green, leaving only the slightest amount of memory free.
No specific flows seem to cause this. It happens over time. The longer the server has been running without a restart, the worse it gets. It grows and grows and then eventually levels out seemingly on its own, but inactive memory never drops down to what I would call "normal" levels.
Seems like a memory leak but I can't seem to pin point what is causing it but I know Switch has something to do with it.
OSX users, have RAM issues with Switch?
Here it is, a few hours later. It's after hours here and Switch is sitting idle without any real work to do. It's pretty typical for our machine to sit in a state like this:
ArielRauch
Hey Gabriel,
have you reported it to Enfocus? Could you please keep us posted? Thanks
Ariel
Ariel
I haven't reported it because it seems difficult to troubleshoot. Perhaps I will give it a try though.
We have since upgraded to a Mac Pro on Yosemite (with 64GB of RAM) running Switch 12 Update 3 and we're seeing similar results:
dkelly wrote: What applications are using the most memory? In Activity Monitor sort by Real or VM Memory Usage columns.
Nothing ever really shows up:
