Archive file
kmcrae
i how can search folder and archive file on the network with the name file?
Thanks!
jonasy
The standard Switch tools allow you to do the following:
The "Submit hierarchy" can input folders from a network volume. This way you can input the parent folder of the archive in your Switch flow. You can then extract the archive from the parent folder.
The "Submit Hierarchy" allows you to use various rules to choose which folders are imported from the network volume and which aren't. It is currently not possible to use filtering rules based on files. It is a known feature request, so it might be possible in the future.
It might be possible to write a script that does what you want in a better way. On Mac you can do a spotlight search using the mdfind command, I think a script using this command could do the trick.
