Hi all,
I installed Switch V12 recently and I have many troubles. V11 was perfectly fine. Is it just me ?
For example, my view is randomly changed, some flows cannot be stopped once ran. Some operations, even the simpliest ones, fail to execute.
I have a MBP with OSX 10.7.5 installed if this can help.
Best to all,
Is Switch 12 buggy ?
Hi DKelly,
Thanks for your feedback. I feel a bit les lonely
I will report to enfocus as well. Fact is I installed 12 over 11 and maybe the installation was corrupted somehow.
I did a fully uninstallation, tracking every single piece of files related to Switch and re install over. For what I can see, it looks like more stable now.
FWIW,
Best,
FWIW,
Best,
MitchSharpe
Ive had a few issues with 12 and have stopped using it. Thankfully ive had issues with updates before so always try out the software first on a separate machine using a special Developer licence.
I stopped as soon as I ran a test archiving job which should have moved files from machine to machine and put them back into the same folder structure, but instead I found files sitting at the top level of the folder structure ...
Hang off until 12U1 id suggest ...
Hi Mitch,
to make sure that we can solve the issue, it would be very helpful if you could report it to our support:
support@enfocus.com
Thanks a lot in advance.
Antje
support@enfocus.com
Antje
I seem to have a users based issue.
When connecting multiple switch clients using anything other than the Admin account I have no connection or at best one that connects and then disconnects after a few minutes.
Default Switch Admin account connects without issue.
Waiting for a response from Enfocus.
Cheers
Cheers
mervinator
aoswood wrote: My only issue with the new version is SWITCH Designer is slow to refresh, activate and deactivating flows.
I am also experiencing this. The file count on folders don't seem to refresh real time as was with Switch 11. Same is true for me with activating and deactivating flows. On several occassions, I've had to force reboot my server just to restart Switch.
Joerg Schober
Also my experience: The file count on folders is not usable in v12. It sometimes lasts dozens of seconds until the real number of files is shown. I assume the reason for this is the introduction of Remote Designer (which I can't use as it crashes here).
Kind regards,
Jörg
Kind regards,
Jörg
I made good experience with Update 2 on Windows Server 2008 R2. We use it in combination with Pitstop Server 12 and callas PDF toolbox. There are some issues with AD integration, but I'm looking forward to the next update.
Best regards,
Thomas
Best regards,
Thomas
numnational
Hi all,
With the last update, upgrade 3, this problem is fixed here.
Great news
Great news
