First of all I wish you all merry christmas - and I assume that no one is crazy enough to connect to crossroads these days:)
Nevertheless, I am trying to use "submit hierarchy" to pull out of a hierarchy all the relevant files and via the output connection parameter (include folders/exclude folders) decide which path the files should take.
Unfortunately, the flow always takes all the files to all the paths - even though I defined for one path: include pattern: EPM*
and for the other "all the others"
Someone out there?
Ariel
submit hierarchy - how does it work!!!
ArielRauch
The number of levels is also important when using "Submit hierarchy". Perhaps that is where your problem lies.
ArielRauch
it is good to have you back! Too long vacation is not healthy:)
No, put even a greater level than actually required.
I "solved" it now by adding hierarchy information to the files and later in the connection after an intermediate folder I filter according to the hierarchy info.
