JSON Dataset
JSON Dataset
What's the simplest way to take a JSON response and convert it to a data set that Switch can use?
JSON Dataset
var jsonString = '{
"glossary": {
"title": "example glossary",
"GlossDiv": {
"title": "S",
"GlossList": {
"GlossEntry": {
"ID": "SGML",
"SortAs": "SGML",
"GlossTerm": "Standard Generalized Markup Language",
"Acronym": "SGML",
"Abbrev": "ISO 8879:1986",
"GlossDef": {
"para": "A meta-markup language, used to create markup languages such as DocBook.",
"GlossSeeAlso": ["GML", XML]
"GlossSee": "markup"
var parsedObject = eval("(" + jsonString + ")");
s.log(2, parsedObject.glossary.title);
JSON Dataset
Sorry Dwight, I think I was unclear. Yours is a little more concise but I have been doing something similar:
var objJSON = eval("(function(){return " + JSONString + ";})()");
What I'm after is trying to take a big JSON object and easily get it into Switch metadata somehow. Right now, I have to do something like you suggested and above and write each key to Private Data. I'm wondering how you could take a big, complex, JSON object and put it into a Switch dataset somehow so you could reference all of the values in the flow later.
JSON Dataset
There are many Javascript JSON2XML converters that should work with small modifications to remove unsupported Javascript language features such as 'object.constructor'.
