Change page start
nurhood
Hi there,
How do I set page number to start with page 1 in pitstop pro preflight report?
Can you explain this a bit more? What type of report are you using? Does it have something to do with the fact that the first page of the document is not called 1, but something else (perfectly possible in PDF)?
nurhood
I mean the XML preflight report. In the report, I notice that the 'check' will start with page 0 instead of page 1. Example:
34936.21 sq mm
2035.39 sq mm
See Location @page. This is actually for page 1 in the PDF file.
Engineers have this tendency to think of the first element of an array as being 0 :(, so I am afraid this is what it is.
