Dear All,
after Bens quite nice primer on creating an XML file it's mostly clear how to author such a file. However, I ran into a problem using those methods: how can I actually change a value in an existing XML by using a script?
After studying the manual and the reference I can't help just to acquire all the data out of an existing XML and create a new one with the altered data. There has to be an easier way to change just one value in a node, without re-creating the whole file. Example:
original:
ABCDE
after the script I want to have a file like this:
FGHIJK
I guess this has to be pretty simple, just I can't find any reference to this. Any help appreciated,
Kind regards,
Peter Nagy
Replacing values in an XML by a script
Szia Peter,
Unfortunately the only way to change an XML is to completely re-write it. But this is not really as bad as it sounds: the whole parsing and rewriting part is done in the background. There are only 4 steps to go through:
1. open the XML
This is a single line:
var xmlDocument = new Document( "/path/to/file.xml" );
2. locate (the parent of) the node you want to change
Depending on your needs, this too may be a single line:
var theNode = xmlDocument.evalToNode( "/jobInfo/code" );
3. change the node
This involves getting the node you want to change (=the existing node), creating a new node, and calling replaceChild(). For example:
var theNewTextNode = xmlDoc.createText( "FGHIJK" );
theNode.replaceChild( theNewTextNode, theNode.getFirstChild() );
4. save the file
Again, a single line:
xmlDoc.save( "/path/to/newfile.xml" );
In a real situation you'll have more code than this of course - but for your example these 5 lines already work
1. open the XML
3. change the node
4. save the file
reprokaiser
Hi Bens,
thanks for the quick reply, it's working perfectly!
Kind regards,
Peter
Kind regards,
Peter
Clive Andrews
OK - I'm still in trouble...
To try and get my head round this - it took your script parts, and edited them to initially just change the job number:
var xmlDocument = new Document ( "C:/Tests/101615.jdf" );
var theNode = xmlDocument.evalToNode( "/JDF/JobID" );
var theNewTextNode = xmlDoc.createText( "103999" );
theNode.replaceChild theNewTextNode, theNode.getFirstChild();
xmlDoc.save( "c:/Tests/103999.jdf" );
But all I'm getting is "Expected end of statement" error - 800A0401
Mr Microsoft says I'm missing something - but after half a day of trawling and editing - I can't see what. My theory is if I can prove this, I want to use the same way to extract data from a node - and pass it onto another (or as part of the same) script...
I know, new boy, doesn't understand and all that - but I'm getting there virtually self taught!
Clive, the syntax error was caused by missing parentheses.
However, the code won't work even after you fix this problem because JobID is an attribute not an element. Here's the correct method.
var xmlDocument = new Document( "C:/Tests/101615.jdf" );
if (xmlDocument != null) {
var theElem = xmlDocument.getDocumentElement();
theElem.addAttribute( "JobID", null, "103999" );
xmlDocument.save( "c:/Tests/103999.jdf" );
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Clive Andrews
Thanks, once again, are in order Dwight - that gives me something to build on!
Clive Andrews
dkelly wrote: Clive, the syntax error was caused by missing parentheses.
Dwight - still getting errors- "Expected end of statement" on Char 31 - i.e. at end of 1st Bracket (var xmlDocument = new Document()- am I just a bit thick here, it's on a Win server 2003 machine if that helps...
Clive, I just reran the script and it worked fine here. Can you send me your flow and I'll take a look?
Dwight Kelly
dkelly@apago.com
Dwight Kelly
dkelly@apago.com
Clive Andrews
Ah - therein lies the probable fault, I was kind of hoping to call this from the Apogee machine - I have an AGFA script to call an archive to be recovered, which works manually - I'm trying to tie that into a rename routine, to call an archive back - and then update the files to a current job number. (The Apogee script has to be local as it calls a service)
Classic case of desire exceeding my ability I think!
