[SOLVED] PDFTK command arguments issue
loicaigon
Hi all,
Given the PDFTK command line utility, this line works fine in terminal :
pdftk "/Users/sunsikim/Desktop/toto.PDF cat 1-2 output /Users/sunsikim/Desktop/totoP1-2.pdf"
Once I try to use it through Switch Execute Command, I can't get it to work
Command : pdftk
Arguments : "/Users/sunsikim/Desktop/toto.PDF" cat 1-2 output "/Users/sunsikim/Desktop/totoP1-2.pdf"
t's just a copy/paste plus the double quotes for the paths. I am just expecting to get the output pdf but none are created. I am conscious here that it won't output the file in my connection. I am ok with that right now.
For starters, I just wish that the PDFTK command just works.
Anyone has ever used PDFTK with Switch ? Does anyone see what I am doing wrong here ?
Thanks in advance for your hints.
loicaigon
It appears I made the #1 mistake ;)
http://www.enfocus.com/en/support/knowl ... mand-tool/
HTH,
pcarvalho
I had the same issue and solved like this:
Exetution Mode: Concurrent
Comand or path: the path for the PDFTK
Arguments: "%1" output "%2" owner_pw password
Output: File at path
Copy input Job: yes
Output extension: Automatic
Fail exit code is: Disregard exit code
Don't forget the quotes in the argument "%1" and "%2"
