Metrix JDF to Dynastrip
PaulHough
Hello everyone,
We just recently purchased EFI Pace w/ Metrix.
We have been using Dynastrip for imposition for awhile and our prep team really likes it. Now with Metrix comming on board what I would like to do is have efi pace/metrix create a JDF and drop it into our job folder via switch. From there I would like to be able to open the file using dynastrip.
Currently I don't see a way for me to open the jdf file because metrix says "it does not contain imposition data."
Any ideas or comments are greatly appreciated.
TOP CONTRIBUTOR
JDF is just XML. Your Switch flow can create or modify JDF as required.
Metrix uses a JDF proprietary spinoff called MXML and will output several types of JDF's out of Metrix. You can then set Metrix to export those JDF's (let's say your cutting one), to a folder Switch can watch for and automate to your cutter.
Here's a simple example of using Switch to send a JDF directly to an Indigo: https://github.com/dominickp/SwitchJMF/ ... /Status.js This can be done much better now adays with the HTTP class.
If you're interested in making your own JDF's, I started working on some classes to make it easier in PHP: http://jdf.dominick.p.elu.so/generator.php
If you have Indigo's, there is a SmartStream configurator which will make a JDF from Switch as well.
ArielRauch
For Indigos the DFE Configurator still misses some of the feature that are supported by the DFE tickets.
A new version (like always) should add those missing features:)
mattbeals
Metrix JDF is in no way proprietary. Metrix XML (MXML) is.
What are you trying to do with the Metrix JDF in DynaStrip? There is JDF that has imposition information, there is JDF that has job information. There can be JDF that has both. Since this is a Pace/Metrix combo we probably ought to handle this through Metrix Support ( metrixsupport@efi.com ).
