I've been staring at this for a while now. If a customer uploads a ZIP, I can split the ZIP and xml with no problem. The xml that comes with the file is created by iDropper - and contains the file manifest that I use to build the archive hierarchy at the end of the flow...
So....
If I unzip a file and it contains multiple files, I guess I need to amend the xml with the new hierarchy - to merge it all back together and archive it...
Any suggestions anyone..?
How do I unzip a batch of PDFs, and add info into xml to reflect new file list...?
Clive Andrews
Hi Clive, it appears that the iDroplet XML only contains the ZIP filename. Do you want to add a entry for each file that was extracted from the zip? Do you want to remove the ZIP filename also?
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Clive Andrews
That's exactly it Dwight,
A normal iDropper XML would have
9.pdf
10.pdf
11.pdf
12.pdf
etc....
No zip - that should be discarded. I guess I'm back in the realm of my nemesis "Mr Scripting"...
9.pdf
10.pdf
11.pdf
12.pdf
etc....
