Select printing paper based on pdf size
I wonder i can create flow if the overall image is less than 8"*10.5" then it would choose to print to 8.5"*11" paper but if it is a larger image it would set to print 11" * 17" paper using switch or pittstop pro server.
thank you.
thank you.
Re: Select printing paper based on pdf size
Sure you can. Switch's metadata can collect statistics about a job including PDF page size. You can route jobs using the connection line's "Condition with variables" with 2 conditions that check the page width and height are less than or equal to 612 and 792 respectively (8.5 x 11 inches in point units). If the page size is greater than that you would route to the other connection.
A couple of gotchas:
- Switch only collects stats about the 1st page in the PDF
- The units are in points not inches
- Be careful about rounding problems. Set the precision value to 0 or 2 so the page size values are consistently formatted
thank you for the quick response.
now i know that switch can assign different route based on size of paper but where i set the size of printing paper?
I gave the detail above. The variables are: [Stats.PageWidth:Precision="2"] and [Stats.PageHeight:Precision="2"]
Yes i understand that i can set the route depends on paper of the size.
But how and where can i make printer to print pdf on 11*17 size paper if its bigger than letter size pdf?
Thank you very much.
Scale the page size with Pitstop, pdfToolbox, PDF Enhancer or an Acrobat script.
I thought i would be able to let switch automatically select those paper sizes and paper sources like what i would do manually in the picture.
Problem is if i set Yes for the 'Auto-choose paper source' in property. it would choose best fitting paper size for pdf so that is not always either letter or 11*17.
I want printer to choose only letter or 11*17 if its bigger than letter size.
Thank you
Switch has no built-in support for sending files to a printer via print driver.
okay
thank you for your time
you can do it using the "Execute command" and Ghostscript.
There is parameter -sPAPERSIZE, but I don't see parameter for Paper source.
Aleksander
can you show me screenshot of flow and property panel? I would very appreciate.
also, i wonder if i need to install something to learn ghost script on switch.
Thank you
Thank you
flow might look like this
In Arguments line:Where "HPLaserJet" is name of your printer
Output: None
In Arguments line:
-sDEVICE=mswinpr2 -dBATCH -dNOPAUSE -dNoCancel -sPAPERSIZE=a3 -sOutputFile="%printer%HPLaserJet" "%1"Output: None
Aleksander
Sorry.. forgot to tell you that switch is running on mac. do you know what should i have instead of "mswinpr2"
thank you
thank you
Unfortunately, I do not know mac.
See this page: http://www.gnu.org/software/ghostscript/devices.html
I suspect that you can use os2prn, or specified driver.
Aleksander
thank you so much for your help.
