At first I had the JDF Control set up to send the file to the RIP of the press, but I then changed it to a local folder on the computers desktop, but I still get the same error.
Any ideas what might cause this problem?
Thanks Gabriel. Got it working now!gabrielp wrote:I remember this error. I think it has to do with the fact that the DFE needs the asset location when it later reads the JDF but Switch needs it to so it will place the document there. So both Switch and the DFE need access to the asset location from the same network path. The easiest way to do this (I think) is to use a path on the DFE and make sure Switch has the DFE's volumes mounted and can write to that location.
Hope this helps.
I don't think you should put the asset-file in to the actual jdf-folder. Make a folder outside the jdf-folder, and then put the link to this folder. See Gabriels first answer, he calls it "\PageDNA". I call it "\jdf-asset".LasseThid wrote:Thanks Gabriel. Got it working now!gabrielp wrote:I remember this error. I think it has to do with the fact that the DFE needs the asset location when it later reads the JDF but Switch needs it to so it will place the document there. So both Switch and the DFE need access to the asset location from the same network path. The easiest way to do this (I think) is to use a path on the DFE and make sure Switch has the DFE's volumes mounted and can write to that location.
Hope this helps.
When I clicked my way on to the server and the correct folder the path was Volumes/Jobs/JDF, but I changed that to \\HPRO1-SM1\Jobs\JDF and it worked right away. *thumbsup*
<RunList ID="RunList_1" Status="Available" Class="Parameter">
<LayoutElement>
<FileSpec MimeType="application/pdf" URL="FILE://hppro1-sm1/jobs/Switch/Asset/1514467_21102015-162319860.pdf"/>
</LayoutElement>
</RunList>
<LayoutElement>
<FileSpec MimeType="application/pdf" URL="test.pdf"/>
</LayoutElement>
<LayoutElement>
<FileSpec MimeType="application/pdf" URL="FILE://hppro1-sm1/jobs/Switch/Asset/1514596_22102015-093712034.pdf"/>
</LayoutElement>
