I'm searching for a javascript code, which allows starting an Acrobat X profile with corrections (for example "convert to PDF/X3 Coated FOGRA39") using the Acrobat module of PowerSwitch 09 Update 3. At this point of the flow, I don't want't to use the pdfToolbox5 module instead on purpose.
Has anybody some pieces like this?
Thanks in advance!
Thomas
OSX 10.6.8 / PowerSwitch 09 Update 3 / Acrobat X
JavaScript to start xxx.kfp with Acrobat X
You could try creating an Acrobat X Action that calls Preflight with the "Convert to PDF/X-3 Coated FOGRA39" setting. Next using Acrobat IAC to launch Acrobat, open the PDF, call the Action and save the PDF.
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Hello Dwight,
unfortunately I'm not able to test this idea by myself, but I'll discuss this possibility with our IT team.
Thank you!
Thomas
Thank you!
Thomas
