Send email after sending all jobs
Qpdv
I have a flow that retrieves a folder with pdf files. But now i would like to send an email when a folder has been transferred instead of the separate pdf files/jobs.
Hierarchy
-DIR_001
--101
---Pdf1.pdf
---Pdf2.pdf
--102
---Pdf1.pdf
---Pdf2.pdf
So when folder 101 or 102 hes been transferred i would like to receive an email. These folders could contain more than 100 pdf files so receiving an email per pdf would be a little annoying :)
Thanks in advance
sander
This picks up a folder, and one mail is send per folder. Both arrows transfer 'all jobs'.
Folder 101 and folder 102 hold both a couple of files, results in two mails;
Hello, it's me
Email was triggered by this folder :
101
   Device, EPM+K.pdf
   Device, EPM.pdf
Hello, it's me
102
   Device, CMYK.pdf
   Device, Grayscale.pdf
   Device, IndiChrome.pdf
This is what you are looking for?
Part of my playground:
BartDenolf
I have the same problem, but the suggested answer above keeps triggering a mail for each item instead of each folder.
Does anyone have a solution?
Thx Bart
sander
Is your input a folder or separate files?
BartDenolf
A folder containing lots of different files.
Bart
sander
Strange, it should pickup the whole folder at once. Can you screenshot your folder structure / flow maybe?
BartDenolf
Included is a screenshot of a part of the flow.
- The set hierarchy alters the hierarchy so one subfolder is added at the top
- The rename job is there because all info is added as prefix and has to be removed before everything is placed in the archive folder
- The small sidetrack is build because the client wants jpg files from all files who pass the flow. The rename is used to add a suffix "_portal" at the end of all the jpg's.
Thx
Bart
Screen Shot 2017-02-06 at 15.45.00.png (22.04 KiB) Viewed 60513 times
sander
I'm not 100% sure but I'm not sure if Set hierarchy path will create a folder?
You can add a Assemble job between your temp » Mail send so it will assemble a folder which will trigger the Mail send only once.
BartDenolf
At this moment I'm experimenting with Assemble job but until now I have no success with it.
Bart
sander
Post this part of your flow and I'll fix it for you ;)
BartDenolf
If set the Submit hierarchy in an earlier flow to subfolder levels 1 in stead of 10 and let it follow with an Ungroup job. Just before the mail I do an Assemble job. That does the trick.
Thx for all the help!
Bart
