Hello all,
I am trying to create a flow that will add variable data to a file that is run through a Switch flow. I have the HP SmartStream Designer VDP, I am just not too sure how to utilize its abilities. I do not have the Enfocus scripting module. The file I am testing with needs the serial number, in the top right corner, to be incremented by one.
Any help is appreciated! Thank you!
Variable data help.
Re: Variable data help.
Hey,
Would need more specifics about the issue you're looking to solve, but we discussed some generics on how to use the SmartStream VDP configurator in this thread: http://forum.enfocus.com/viewtopic.php?f=12&t=1163
