Hi All,
I'm having a hard time with sending JDF's forward as a Mime Package. Bellow you'll find the errors I'm getting. Has anyone experienced this before? Im running Switch13 and HP Digital Front End JDF Control (version 8)
Failed to run external process: java -Dlog4j.configuration=file:\C:\ProgramData\Enfocus\Switch\11\scripted-plugins\com.enfocus.HP~Digital Front End JDF Control\MimeUtil\log4j.xml -Xmx500m -classpath C:\ProgramData\Enfocus\Switch\11\scripted-plugins\com.enfocus.HP~Digital Front End JDF Control\MimeUtil\lib\* com.hp.cp.mimeUtil.MimeUtil -pack -mime C:\Users\Administrator\AppData\Roaming\SmartStream Configurators\JDF\A201504220972G860KG_redo_dx08ao_21429735210_BismarkElementary14-15FINAL_4.21.15.pdf.mjm -jmf C:\ProgramData\Enfocus\Switch\11\scripted-plugins\com.enfocus.HP~Digital Front End JDF Control\MimeUtil\SubmitQueueEntry.jmf -jdf C:\Users\Administrator\AppData\Roaming\SmartStream Configurators\JDF\A201504220972G860KG_redo_dx08ao_21429735210_BismarkElementary14-15FINAL_4.21.15.jdf -assetdir C:\Users\Administrator\AppData\Roaming\Enfocus\Switch Server\temp\14\ScriptElement\2\1
Thanks a bunch!
HP Digital Front End JDF Control Configurator Sending MIME
I've seen messages in my logs saying the configurator is looking for a java runtime, which it needs to run.
Might be worth a try to install?
Part of my playground:
Great to hear!
Reboot is the magic word haha
