Get list of PDF-files from folder to populate drop-down
JimmyHartington
Post by JimmyHartington »
Hi
I am creating a flow, where I start with a Submit Point.
And I would like to have the user fill out metadata.
One of them should be a dropdown of files from a folder on the Switch-Server.
The contents of the folder will only be pdfs but it the number of pdfs changes over time.
I tried to set the Data values of the dropdown to a script expresision (see code below), but SwitchClient just shows me a text-entry field. If I set values manually, then I get a dropdown.
I hope somebody can help.
var theDir = new Dir("D:\SB-S\kursussystem-v2\APPROVED");
var theEntries = theDir.entryList("*.pdf", Dir.Files, Dir.Name);
	var list = new Array;
	for (var i = 0; i < theEntries.length; i++)
		list.push(theEntries[i]);
	list;
loicaigon
Re: Get list of PDF-files from folder to populate drop-down
Post by loicaigon »
Not helping but your code just works fine onto my mac :S
Terkelsen
Post by Terkelsen »
Hi Jimmy ;)
Try This:
var theDir = new Dir("D:\\SB-S\kursussystem-v2\APPROVED");
list.push(theEntries);
list;
The extra backlash made all the difference for me.
JimmyHartington
Terkelsen wrote:The extra backlash made all the difference for me.
Thanks to Erik to point me in the right direction.
I needed to use doublebackslash in the complete path. And then it worked.
I have added some extra-code to remove the extension of the filename.
Finished and working code:
var theDir = new Dir("D:\\SB-S\\kursussystem-v2\\APPROVED");
  list.push(theEntries[i].substring(0, theEntries[i].lastIndexOf('.')));
list;
