Remap SpotColors with Switch
NEOSA
Hi All@Forum,
I try to setup a SFLOW with Switch to remap SpotColor.
My intend is to catch SpotColor values from incoming PDF files, build a list of available colors (by reading values from a PitStop Server XML Report) and remap them to a new one.
I tried to build with CheckPoint in SWITCH, with conditionals items : 1,2 or 3 SpotColors.
Example : If EndUser select 3 Spots, SWITCH should show the list of the 3 spotcolors used in a PDF file (in a drop-down list), and a field where this EndUser will type in the new desired spotcolor (or may a pre-defined list).
Tools to be used : SWITCH CoreEngine & MetaData / PitStopServer. Do we need extra options (Scripting) to perform such actions ?
Have any of you experienced this with Switch ?
Thanks for replies ;-)
