Change Xml values
sodslaw
Change Xml values
Post by sodslaw »
In an xml how would I go about reversing the width and height values within a flow in switch?
I take I would need a script of some sort to achieve this?
Any takers to show me how I could incorporate into a flow in switch would be much appreciated
Cheers
Sod
Re: Change Xml values
Post by gabrielp »
sodslaw wrote:In an xml how would I go about reversing the width and height values within a flow in switch?
Why do you need to reverse the values?
There are several solutions to this, depending on what you want to do:
- If the dataset is writable, you could overwrite the dataset values
- Write the values to private data (if you can't script, use metatagger in appstore), then just overwrite them in private data as needed
- Route your flow logic so you don't need to overwrite values
sodslaw
Post by sodslaw »
Thanks for your help - will look into your suggestions
Sod
Post by gabrielp »
sodslaw wrote:Thanks for your help - will look into your suggestions
No problem. If you get stuck and can be more specific, I can give you a more specific answer. Good luck 8-)
