InDesign Config Can't See Images
rgpepper
Trying to process some InDesign files, I'm submitting package folders to my flow, but InDesign refuses to see the images, always errors if I check "Fail with unavailable images". And the error lists the name of every image in the document. But it's bogus, all the images are in the (InDesign created) "Links" folder which is in the submitted job folder (that InDesign created on the source side). Source files are from a Mac, Switch is running on a Windows server but that shouldn't matter, verified v4 of the ID plugin for Switch, CC2015 on both machines = no joy.
That's very strange. And if you open the InDesign file on the Windows machine, it shows the images and doesn't prompt to re-link anything, right?
rgpepper
It shows them missing, but I can re-link to them (in the package folder on the Switch server) fine. So it's not a rights issue, it's like it doesn't know where it's supposed to look when told to re-link. Enfocus tried my flow (on a Mac) on their end and it works fine. Doesn't work for me, always says images are unavailable. Curious thing is, if I turn off the re-linking and the warning, the flow produces a PDF that preflights fine and appears to have the full resolution images in it.
Sounds like a bug to me. Maybe others who have some experience with the InDesign configurator could speak more about it. I would see if Enfocus support could reproduce the problem on their end if they run it on Windows.
rgpepper
They can't reproduce the error. I've tried one of their two suggested tests to isolate the cause, that didn't reveal anything new, working on the second one.
If you'd like to PM me some test files/flows, I'd be happy to try this on my OSX system to see if I can reproduce it on my side.
Zoranj
Did this get solved?
I am having similar issue, where I am getting a list of all links and fonts instead of only problem ones.
13.1 Switch, on Windows 2008 R2 server, configurators updates to the latest version, Adobe CC same.
