Resizing and creating thumbnails
Hi guys,
Has anyone found a way, without using the Photoshop configurator, to "fit resize" thumbnails? Meaning, I want to take a PDF, create a thumbnail of the first page, and resize it so its longest dimension is 350 pixels, without distorting its aspect ratio. PDF2Image only takes inline values for the fixed width/height, so if I calculate the resized aspect ratio, I can't use it within PDF2Image.
The documentation of the PDF2Image configurator says:
Image dimensions
If 'Resolution' is selected, the page will be rendered at given resolution. If 'Fixed with and/or height' is selected, the page is rendered at given width and/or height. At least one of Height or Width must be defined. If both are defined, the aspect ratio is not maintained.
In other words, specifying one of the two values will do. You will have to have two instances, one for portrait and one for landscape with a condition.
jan_suhr
I'm at the moment making an APP for that, will be ready anytime soon :-)
Jan
Jan Suhr
Color Consult AB
Sweden
Check out my apps
freddyp wrote:In other words, specifying one of the two values will do. You will have to have two instances, one for portrait and one for landscape with a condition.
Perfect! It's very nice having you on the forums now :)
jan_suhr wrote:I'm at the moment making an APP for that, will be ready anytime soon :-)
Nice man. I'll probably be your first customer 8-)
Freddy, why don't they accept a variable for those dimensions? It makes so much sense to allow for one there. :cry:
bens
gabrielp wrote:Freddy, why don't they accept a variable for those dimensions? It makes so much sense to allow for one there. :cry:
That's an oversight and will be fixed for the next release. Thanks for pointing it out :-)
jan_suhr
The thumbnail app is now published:
https://appstore.enfocus.com/product/makeThumbnails
Jan
Jan Suhr
Color Consult AB
Sweden
Check out my apps
