Filter on XML Error
KaesDS
Hey guys,
I'm working on a quite simple flow to sort pdf files with the help of metadata attached to it.
The XML pickup part is working fine, but the filter causes an error. :cry:
Fehler in Zeile 29 des Skripts Metadata.Text: TypeError. 'evalToString' undefined or not a function
The german part means "Error in line 29 of the metadata script". I'm pretty sure that my filters (XPATHs) are right. :cry: :?
Also already tried it with different types of data. (INTEGER, TEXT, Boolean) Error remains the same. :?:
Two screenshots of my flow attached.
We are using Switch 11 and maybe there is some kind of bug in the metadata-module?
Or is this error caused by the guy infront of the screen? :lol:
Thanks in advance! ;)
Greetings
Kristoffer
lombert
The line should look like this;
[Metadata.Text:Path="/order/template",Dataset="Check_Input",Model="XML"]
There "Check_Input" is the line you get from XMP-pickup's 'Dataset name'.
Then I do this I set two folders after XML-pickup and sets the connection between the folders on hold, then you can see the "job" that you want to pickup meta data from in the window.
Between jobs!
KaesDS
Thank you lombert, it's working now! :D
Especially the hold "trick" was perfect!
