Inject job keep Private data
Qpdv
I'm trying to inject a job but i need the private data in that job. But when i inject it its gone.
Peter
sander
Are you are injecting from a static job repository?
So, a file with stripped unique name is the injected job?
Part of my playground:
Qpdv
What exactly do you mean by static job repository?
sander
Like this, with this settings my private data is not discarded, that's for sure :)
Qpdv
Yes that thats the one.
Qpdv
Even from the job thats injected?
sander
Yep, without private data a file dies within one hop in my flows :)
Can you screenshot your settings?
Qpdv
Screen Shot 2016-12-08 at 12.02.56.png (18.89 KiB) Viewed 72435 times
sander
Weird, looks like the same settings over here.
Hmm, what's in your Job name variable?
Qpdv
Only: [Job.NameProper]
sander
Wow! Sorry man, I think I misunderstood somewhere. My inject job and original job do have the same metadata, so the metadata is not of the injected job but the incoming job.
However, since the injected job does not have the unique name anymore all metadata of this job is discarded, I bet there's no way around that one.
sander wrote:However, since the injected job does not have the unique name anymore all metadata of this job is discarded, I bet there's no way around that one.
True but could the job being injected be packed? If so, you could inject and unpack, keeping the metadata.
