We want to make a flow for it work to take a file and copy a folder with the same name as file.
At the begining we put a file a file it name is ABC015489L and the end of flow we have a folder and inside there are more folders with diferent names (ABC015489L, COM029874J....we don´t know how many) and Error folder.
If exist the folder copy the file inside and if it is not exist copy the file to Error folder.
I know i need a script.
Im preparing one, but I don´t know how to get up the list all folder to compare the name file with the name folder.
Could you help us please?
Copy a file inside to the same name folder
the basic code needed would look like this:
var folderPath = s.getPropertyValue( "folderPath" );
var folder = new Dir( folderPath );
var entries = folder.entryList( job.getNameProper(), Dir.Dirs | Dir.NoDotAndDotDot, Dir.Unsorted );
if ( entries.length > 0 )
job.addBottomHierarchySegment( job.getNameProper() );
else
job.addBottomHierarchySegment( "Error" );
else
Hi rzatzel,
Thanks for you help.
Perhaps I haven´t explained very good.
Attchement the script. But I can´t get up the list of folder
The first we take the file name only until first white space (normally 10 or 11 caracters)
Then we need take the list of folder in path (the path is F:/OUT/) and copy in the same folder as the file´s name (the folder name begin with 10 or 11 caracters of file´s name and then others caracters but these caracter as not important). If the folder is not exist, it copies to Error folder the file.
Best regards
The script:
For example i put two file ABC0123451 ZZZZ.pdf and CON029867J ZZZ.pdf, the First file exist a folder name ABC0123451 XXXXX and the second no exist any folder, It goes to Error Folder
var pathOri=job.getPath()
var nombre = job.getName();
nombre=nombre.toUpperCase();
var letras=nombre.indexOf(' ');
var nombrec=nombre.substring(0,letras);
var path = "F:/OUT/";
var myDirectory = new Dir(path);
//Here I can´t get up only the list of folder
var carpetas=myDirectory.entryList("*.*",Dir.All,"");
for (var i = 1; i //Here copy the file to F:/OUT/ABC012345l XXXXX/ABC0123451 ZZZZ.pdf
else
job.log(1, "incorrecto");
//Here copy the file to F:/OUT/Error Folder/CON029867J ZZZ.pdf
Best regards
The script:
else
the script code does with minor changes (you didn't explain the naming conventions before) exactly what you want.
All you have to do is to copy the code into a script package and create a script property named "folderPath", put a "Script element" in your flow and assign it this newly created script package and to put an "Archive hierarchy" flow element at the end of your flow.
Here's the modified code:
var shortJobName = job.getNameProper().match( /^[^ ]+/ );
var entries = folder.entryList( shortJobName + "*", Dir.Dirs | Dir.NoDotAndDotDot, Dir.Unsorted );
if ( entries.length == 1 )
job.addBottomHierarchySegment( entries[0] );
else
job.addBottomHierarchySegment( "Error" ); //or whatever to do if more than one directory matches
else
else
else
Hi rzacherl,
I have changed your script because I don´t know how to pass a argument into script. l have looked for swich help but i haven´t found.
This script goes on, but no delete the origen file. I know that this script copy file, no move, but how delete?
If I put " job.sendToSingle( job.getPath());" this sentence it moves the file into F:/OUT/ and the sentence s.copy it copies into its folder. Then I have the file in two places.
Thanks a lot for your help.
Best regards
Miguel
The script:
var folderPath = "F:/OUT/" ;
var entries = folder.entryList( shortJobName + "*", Dir.Dirs , Dir.Unsorted );
s.copy(job.getPath(),folderPath+entries[0]+"/"+nombre );
else
s.copy(job.getPath(),folderPath+"Entrada PS/"+nombre );
else
s.copy(job.getPath(),"F:/OUT/Entrada PS/"+nombre );
Best regards
Miguel
The script:
else
else
Hi Miquel,
seems that you're not familiar with many of the basic concepts in Switch like hierarchy info and especially with PowerSwitch and it's scripting API.
You don't need to copy the job to the final location or delete the original job file by using my script code. The script adds the necessary hierarchy info to the job's job ticket. As I already wrote simply put a "Archive hierarchy" flow element at the end of your flow, assign it the base path F:OUT and everything will work as expected. By using a sendTo...() method the incoming job file is automatically moved from the incoming folder to the selected outgoing connection(s).
Try to get a one day training course for Switch otherwise you really miss a lot of the really cool stuff in Switch.
Regards,
Robert
Regards,
Robert
Hi rzacherl,
I know I don´t know a lot switch, I made a course of elemental switch (no scripting).
Here, I leave the script goes on.
We need create a flow element properties with name "ruta".
The script move the file to a destination folder where are a lot of subdirectory. Always the begining name's file and the begining name's folder.
Thanks for your help rzacherl, if you don´t help me i couldn´t do it
Here the script:
var rutaini
var rutafin
var folderPath = s.getPropertyValue("Ruta" );
rutaini=job.getPath();//ruta de origen;
rutafin=folderPath+entries[0]+"/"+nombre;//ruta fin
else
rutafin=folderPath+"Entrada PS/"+nombre
else
s.copy(rutaini,rutafin );
job.sendToNull(job.getPath());
job.log(1, "mueve de "+rutaini +" a "+rutafin );
Here the script:
var rutaini
var rutafin
else
else
