I need to compare the trim box in a pdf to the trim defined in the xml job ticket.
cwswitch
1) Which part of Switch do I use to pull the info from the PDF? (I have Pitstop Server if required but would still need to know how if that's the way)
2) Which part of Switch do I use to pull the info from the ticket?
3) How do I perform the comparison?
4) Can I allow for orientation mismatches? e.g. 210x297 is good for 297x210
This is to form a drag and drop flow where the sales rep can drop in a job and be informed pass/fail. It's stand alone, not part of a larger flow.
abailescollins
Basically do it in the PitStop preflight profile using a variable in the page size check (set page size to be defined by the Trim Box).
Switch will get the value from the xml and pass it to the check in PitStop.
I'll leave the Switch gurus to tell you how to grab it.
andrewb@enfocus.com
sander
I do it this way, very simple, very effective.
Left:
[Switch.Calculation:Expression="[Stats.TrimBoxWidth]*0.352777778",Precision="1"]x[Switch.Calculation:Expression="[Stats.TrimBoxHeight]*0.352777778",Precision="1"]
Right, set the values from your XML over here.
[Job.PrivateData:Key="HotfolderNaam",Before="x"].0x[Job.PrivateData:Key="HotfolderNaam",After="x"].0
I'm Dutch, all I do is in mm, no points or whatever ;)
Part of my playground:
John.Dean
I just tried to post a lengthy reply and was punished by a timeout. Lost my wall of text. So, see attached flow.
Drop in a folder which contains the PDF and XML. The flow adds a pass_ or fail_ prefix to the file name.
Check PDF Trim.sflow.zip
(18.66 KiB) Downloaded 1291 times
cwswitch
Thanks for the replies, very useful indeed!
