Hello, I'm stuck with this problem and hope you can help me once again.
I assemble several PDFs and than I want to merge these PDFs to one PDF and
name it after all merged PDF names.
I found the variable [Job.NestedName] and thought I can use this to rename the folder, when I view the Example value
I see all values, but in the end the folder name just contain the name of just one File only.
Does someone have an idea?
Merge PDFs and name it after all merged PDF names
The rename element should allow you to do this. You can use a separator to merge all nested jobs names.
Once that done the issue you have is that the parent folder name and extensions are included.
But you can nest the rename actiobs in order to filter them out. It seems that when I nest the renaming action in one signle element it fails but splitting into many will work but will extend processing time.
Once that said it's possibly best to use command line or scripting here
- mergePDFNames.sflow.zip
- (20.61 KiB) Downloaded 381 times
The method with the rename works just fine even with 1 single rename doing multiple actions. Here is how I solved it. After the Assemble job the folder has a name like Job001. In "Rename job" go through the following actions all in 1 single rename:
- Action Replace - Act on Complete filename - with variable [Job.NestedName:Separator="_",Space="trim"] (this puts an underscore between all parts of the nested name, if you want another character use that one, but you will also have to change it in the actions that follow!!)
- The first part (Job001) has to go which is the part before the first underscore: Action Search and replace - Filename proper - Search for regular expression [^_]+_ and Replace by nothing Repeat Once
- Then get rid of all the .pdf_ instances: Action Search and replace - Act on Filename proper - Search for Inline value .pdf_ and Replace by _ Repeat Consecutive
- The final part to get rid of is the .pdf extension: Action Search and replace - Act on Filename proper - Search for Inline value .pdf and Replace by nothing Repeat Once
Chrissigge
Thank you very much for your help, both solutions are working.
I think it didn't worked for me because I did not use Space="trim" and the filename was too long.
