PDF to XML
PDF to XML
I was wondering if anyone knew of an easy way to convert a pdf file to an xml file... I found a web site that would do it, but I wanted to see if there was a way to automate the process through Switch... Thank you in advance...
Re: PDF to XML
You should have a look at http://www.apagoinc.com/ => PDFSpy
PDFSpy can export various things, ans there is a configurator for Switch
Bye
Bye
