Adobe configurators unavailable
Sara_VB
Post by Sara_VB »
Good morning,
I just get Enfocus Switch and I have an issue with my Adobe configurator :
- Switch is running on a Mac where InDesign, PhotoShop and Illustrator are installed
- I've already tried to set path to application
- I've check the version and it's OK
Problem : the configurators are still unavailable (grey color in the flow elements)
Did I forget to check or install something ?
Where did I fail in the settings ?
Thanks for your help !
Regards,
Sara
Re: Adobe configurators unavailable
Post by gabrielp »
Do you have the extendscript toolkit (or whatever it's called) installed? If I recall, some configurators needed that. But that shouldn't cause them to show up grey though.... Anything in the logs when you start Switch?
Sara_VB
Post by Sara_VB »
Thanks for your feedback Gabriel !
Unfortunately there's no Extendscript Toolkit on this Mac.
When I start Switch, no error message or anything else.
Maybe is it because I connect to local Switch Server to try my flows ? (I don't think so, just asking...)
loicaigon
Post by loicaigon »
Did you check if you updated the configurators to the latest version ?
Sara_VB
Post by Sara_VB »
We have uninstalled and reinstalled all the CC, and it's ok now...
