I'm actually testing a flow with a preflight on my PDF.
When I use a standard profile (for example : PDF X1a 2001) the flow is OK but when I set my own profile, I get the message bellow :
The PitStop Server CLI gave an unknown error code: 254
Could someone tell me what does this error stand for ?
Thanks for your help !
Sara
Error code: 254
The PitStop Server CLI error codes are listed in the documentation:
http://www.enfocus.com/manuals/UserGuid ... S/home.htm under "The Command Line Interface - Exit behavior - Error codes.
254 is a PitStop Library error. There should be another log message with the PitStop Library error code and description.
I got this error message twice recently and they were all related to a bad setting in a switch flow while using the PitStop Server configurator.
1) Unspecified variable
2) Messages set as customized but no declared strings
Obviuously I would look at such an issue.
HTH
HTH
